[Rozwiązany] Rambo Mini molex power connectors
Milos V.
(@milos-v)
Hello,
could anyone help me to identify the type of molex power connectors used on the Rambo Mini board? Connectors are damaged and partial melted for the years of service, I would like to resolder it for new ones. But can not find the exact type in the eshops, there are hundreds of them. And Prusa support also does not know.
I believe somebody from the proud MK2x owners must have done it too before 🙂
Thank you.
Opublikowany : 26/06/2021 6:19 pm
Chicago Keri
(@chicago-keri)
RE: Rambo Mini molex power connectors
I believe these are the Molex 3953x series or Eurostyle ESE3953x
Here's a link to one I found
https://www.digikey.com/en/products/detail/0395316002/WM25986-ND/2738782?itemSeq=369311093
A better option might be to solder heavy leadout wires to the board and get the connector and potential failure point away from the board.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Opublikowany : 27/06/2021 5:58 pm
Posted by: @milos-v
Hello,
Thank you.
https://forum.prusa3d.com/forum/older-machines-prusa-i3-mk1-and-older-hardware-firmware-and-software-help/heated-bed-failed-original-prusa-i3-kit-with-mini-rambo-1-3a/#post-221906
wbr,
Karl
Opublikowany : 27/06/2021 7:11 pm
Milos V.
(@milos-v)
Thank you both for your help. The exact part number is 39531-0004.
https://www.molex.com/molex/products/part-detail/terminal_blocks/0395310004
These connectors are the weak point of MK2, that is true. But it served 5 years, so will give it one more chance 😉
Opublikowany : 27/06/2021 9:55 pm
Andreas Balogh
(@andreas-balogh)
RISPONDI: Rambo Mini molex power connectors
Actually I think it's the https://www.molex.com/en-us/products/part-detail/395311007 . The 004 has open sides.
Opublikowany : 16/12/2024 12:22 pm
