PrusaLink with RPiZW2 crashes firmware
Finally got a PiZW2 and added it to my MK3S+. When I set Settings/Port to ON I get a FW error. Same result after resets and power cycles until I turn off Settings/Port. The pi does show up on my network. The MK3S+ firmware is 3.12.2-5713 and the Pi image is prusalink-0.7.2. The pi pins are in the right locations and soldered well with flux. Any help would be appreciated.
Phil
Opublikowany : 06/12/2023 8:24 pm
