Problem reading SD cards on 2.5S / 3.8.1-2869
KaLi
 KaLi
(@kali)
Hi Forum,
since the FW upgrade I have a problem reading SD cards.
The shown content of the card is the first directory-entry multiplied for every element in the directory.
Soo... this shows two entries in the main directory. One folder named PLA_CaliCat, and a file which should have the name 215C_CaliCat_0.2mm.gcode.
Here we are in the sub-directory named PLA_CaliCat... and there should be files beginning with 180C, then 185C, 190C, and so forth. But the first name is shown for every directory entry.
I have this behavious since installing the latest FW. Before this everything worked fine.
It has nothing to do with the sd-card, or the FAT format of the card (via Win10 or via MacOS).
Any help out there?
If only one file is on the SD card, I can print. But this problem is really annoying.
Opublikowany : 08/01/2020 10:54 am
