Printer Stops mid-print...SD Card Error?
Michael
(@michael-22)
This has been happening for several weeks now. Mid print the printer just stops. The display is normal with temps, no errors, etc. When I check the menu, I don't see the SD card listing. I'm not sure if this means the SD card was temporarily disconnected? I have to do a reset and then I can see the SD card list. I've taken the display assy apart and cleaned out the SD slot good (no dust that I can see). I've even tried adding a strap around the SD card to see if that helps but so far no reason why this keeps happening. It's not every print, just randomly...  Any suggestions or ideas as to what may be going on? My printer is an I3 MK2.5S BTW.
TIA...Michael
Postato : 05/11/2023 3:45 pm
The obvious first test is to try with a different SD CARD..?
Postato : 05/11/2023 5:19 pm
1 persone hanno apprezzato
Michael
(@michael-22)
RE: Printer Stops mid-print...SD Card Error?
of course...I should have thought of that already! I'll give this a try. Thanks!
Postato : 05/11/2023 5:21 pm
