Printer printing wrong g code file
Page 1 / 2
GordonMcD
(@gordonmcd)
After many years of faithfully following my instructions my Prusa 2.5S is suddenly being rebellious. I designed a part this morning, sliced it with PrusaSlicer, and loaded it on my SD card. The printer recognizes the SD card, and my new g code appears at the top of the list of files. When I select this file to print, the printer starts printing a different file, one in the third place on the list.
I have saved the file again over the original file. I have done that again after deleting several files from the SD card. I have tried several times to start this print, once even having the printer start the second file on the list.
I am currently printing it from a new, otherwise blank, SD card, and that seems hopeful, but I wonder if there is a simpler fix.
Publié : 21/10/2024 8:25 pm
2 personnes ont aimé
BassoonWN
(@bassoonwn)
Membre
RE: Printer printing wrong g code file
Same here. I'm sure I selected the top file, but once printing, the file that is being printed is a different one.
The file I wanted to print was already on the SD card, but overwritten with a newer one.
Prusa MK3.5S with latest firmware.
Publié : 01/11/2024 9:09 am
roamingt
(@roamingt)
Membre
I am also finding the same problem as well. In the last few weeks this started occurring for 90% of the prints it is reading the third file on the SD card, not the first. I have an MK3S but I wonder if updating the PrusaSlicer to 2.8.1 on a Mac may have coincided with this bug?
Publié : 12/11/2024 6:31 pm
Chris Birkett
(@chris-birkett)
Membre
I am having a similar problem with my MK3S+. I'm using an old version of PrusaSlicer (2.5.2). When I do iterative design of small parts, I often have multiple similar filenames loaded on the SD card. What I'm finding is if the filename is too similar, the printer just prints the oldest one. So e.g. in this example, it will print "spacer xXX.gcode" if I select the other file, or the "2m" version of the other if I select the 1m one. I think I did a firmware update at some point in the last couple months, and I definitely never had this issue before.
Publié : 29/11/2024 3:09 am
GordonMcD
(@gordonmcd)
I have resorted to keeping a clean SD card, with only my latest one or two .G codes on it. Seems silly, but it works.
Publié : 22/01/2025 6:02 am
Patronics
(@patronics)
I'm having the same issue recently, but oddly I'm using the Prusa Mini, so it should have a different firmware stack than the Mk3 series that the other comments are mentioning, so it's interesting they have the same file handling issue. Deleting old gcode files is a functional (but annoying) workaround.
I haven't tested this behavior very thoroughly yet, so it could be a coincidence, but it does seem like at least in some cases changes to the beginning of the filename between iterations may also resolve the issue, suggesting the bug is something about string comparisons on longer filenames?
For example, the file "TK-690 Button Generator-DIM_0.4n_0.15mm_PETG_MINIIS_7m.bgcode" and "TK-690 Button Generator-6 Btn Set_0.4n_0.15mm_PETG_MINIIS_20m.bgcode" were confused by the printer, but making another file named "6Btns Button Generator-_0.4n_0.15mm_PETG_MINIIS_20m.bgcode" was correctly identified.
Ce message a été modifié il y a 1 year 4 fois par Patronics
Publié : 26/01/2025 12:28 am
David Leppik
(@david-leppik)
Membre
Same here on a MK3S with the latest firmware. It suddenly started happening today and persists across reboots. I've been deleting the previous file to keep it from happening.
Publié : 18/03/2025 10:54 pm
goonbee
(@goonbee)
Membre
Also having the same issue on a Prusa XL (Dual head). Also using a Mac Prusa Slicer 2.9.1. Happening very reliably now.
Publié : 02/04/2025 2:18 am
andhson
(@andhson)
I think I ran into this on the core one as well. I sliced a print with the wrong material, re-sliced it with the correct material and ended up with both files on the thumb drive, only the material differed in the name of the files. When I selected the correct material file for printing the printer still picked the other file and refused to print detecting the wrong material compared to what was loaded, this was repeatable. After deleting the file with the wrong material the printer picked the correct file and printed fine. That seems like a bug.
/Anders
Publié : 02/04/2025 6:32 pm
GordonMcD
(@gordonmcd)
My solution, and I'm sticking to it, is to have a SD card dedicated to the file or few files I am currently printing. When it gets crowded before I weed it, I also sometimes scroll below my desired .gcode and then scroll back up to it, but that is mere superstition on my part.
Publié : 02/04/2025 10:39 pm
1 personnes ont aimé
Sulima
(@sulima)
Membre
Still happens on Prusa mk3s, note that I've picked a file with 4:22 print time, but it started to print another file with 3:31 remaining time. Restarting the printer doesn't help. Very annoying.
IMG_6440
Publié : 27/07/2025 7:31 pm
SallyLynn
(@sallylynn)
Membre
RE: wrong g code file - I think it is slicer
I  als0 have been having this problem...picking the top file on the card , but an old version of the model prints out.  Thank you for your post.  I make almost every error but this has happened for several projects lately and it didn't feel like my flub. It seemed like my dementia was coming on unfairly faster than usual.  I have an MK3S+.
I think the problem may be Prusa Slicer writing out the wrong gcode.  Most recently I added a plain pause to my model, and added the message for the printer to show at the pause.  The printer paused and showed the "new" message I entered, but it was printing a previous model.   I believe I had the older model "turned off" with the eye icon when I sliced the newer model.  The viewport clearly showed that it sliced the newer model.   I wonder if slicer disobeyed the "eye" or if it had the old data cached somewhere.   I know the current version was displayed however.  The previous model when printed used a color change pause (my mistake), so this is another way the new file differs from the old one, besides it's features.
I print constantly and I don't know what software changed in the last week or so.
Publié : 01/08/2025 9:52 pm
Beacon Colorado
(@beacon-colorado)
Membre
Yeah same issue here with my MK3S+ with firmware 3.14.1 except I am using CURA. Happens a lot and I also have to format my card a lot. Today I noticed it was also the 3rd in the list that it prints instead of the 1st.
Publié : 03/08/2025 3:21 pm
Johan Vergeer
(@johan-vergeer)
I also have this issue. It seems to occur when the number of files on the SD card is above a certain count. So cleaning the SD card before save a new gcode file on it seems to be the only foolproof solution at this moment.
Too bad Prusa hasn't posted an anwer on this yet.
Publié : 20/09/2025 5:43 am
KP
 KP
(@kp)
The same thing happened to me today with my MK3S, two times in a row.  The first time, I thought it was my mistake.  The second time, I am sure it was not.  I selected this new file to print:
GF Baseplate 4x5 4x1 connectable_0.2mm_PETG_MK3S_2h34m
Instead, it printed (twice!) this file that was older with a similar name:
GF Baseplate 4x4 4x1 22mm padding_0.2mm_PETG_MK3S_2h3m
I have renamed the old file to Special GF Baseplate 4x4 4x1 22mm padding_0.2mm_PETG_MK3S_2h3m and will try again.
Both files were generated with PrusaSlicer 2.9.2 and the firmware version is 3.14.1-8327
Publié : 17/10/2025 7:29 pm
KP
 KP
(@kp)
Posted by: @kp
After renaming the old file, the new file printed correctly.  So this is definitely some kind of bug.
Publié : 17/10/2025 9:15 pm
KP
 KP
(@kp)
Still an issue as of today.  Is there some kind of formal bug report we could make to Prusa?
Publié : 07/11/2025 6:03 pm
Beacon PoiMechanic
(@beacon-poimechanic)
Membre
2026 and I still have this issue. Mk3s running 3.14. Using Cura. Anyone have a fix? Super annoying
Publié : 05/02/2026 6:38 am
Fretco
(@fretco)
Membre
Same here, I just started having this issue.
I believe it started after crashing the printer into a brass brush, that i use to clean the nozzle. It kind of got wedged in between the bed and the nozzle, some sparks flew, because it touched the thermistor wires. Not sure if that may have caused a shock to the PCB...
But keeping the sd-card clean is the way to go for now.
I'll also try to reset the firmware and hope that will solve it.
Did anybody have any sucess so far in getting rid of this irritating problem?
Publié : 22/02/2026 6:49 pm
christopher.a2
(@christopher-a2)
I'm not sure if its the same problem, but I remember that sometimes when you press the button to start the print it can scroll down to the next file and then register the button press, like an interface issue, if you are aware of it you will notice the selection visually and stop the print.
Publié : 23/02/2026 3:44 pm
Page 1 / 2
