Print displacement Y axis
george.s
(@george-s)
I'm having Y displacement issues with larger prints.  I have checked the Y axis pully and Y axis carriage movement and all seems to be fine.
The problem seems to go away when I switch to "High Power" printing but what is going on?  I like "silent" mode better if I can solve the underlying issue.
Thanks
Postato : 13/01/2020 6:40 pm
WileECoyoti
(@wileecoyoti)
RE: Print displacement Y axis
I had this at some point when the extruder was leaking slightly and also when it was over-extruding. In both cases extra goop would be sticking up above the print level, causing the Y axis to skip a step or ten when it snagged. Y axis seemed to be the weakest link in this, at least for me.
Postato : 19/02/2020 9:15 pm
george.s
(@george-s)
The issue is solved.  The Y -axis belt was misaligned.  High power mode covered up the problem,
  I also checked that the linear bearings were operation smoothly and the shafts were lubricated.
Postato : 25/02/2020 10:16 pm
