Print displacement Y axis
I'm having Y displacement issues with larger prints. I have checked the Y axis pully and Y axis carriage movement and all seems to be fine.
The problem seems to go away when I switch to "High Power" printing but what is going on? I like "silent" mode better if I can solve the underlying issue.
Thanks
RE: Print displacement Y axis
I had this at some point when the extruder was leaking slightly and also when it was over-extruding. In both cases extra goop would be sticking up above the print level, causing the Y axis to skip a step or ten when it snagged. Y axis seemed to be the weakest link in this, at least for me.
The issue is solved. The Y -axis belt was misaligned. High power mode covered up the problem,
I also checked that the linear bearings were operation smoothly and the shafts were lubricated.
