Nozzle fan not working during a print
When performing a self test the nozzle fan spins up no problem but then whilst printing it doe's not work at all. In the "Tune" menu it shows the fan speed is set to "255" (max speed) but the fan is not spinning. Slicer has fan set to always on and I have tried a S3D file also with the same results so this must be a firmware or hardware bug? Anyone else seen this issue?
Napsal : 07/09/2018 4:35 pm
