Mk2.5 Firmware 3.3.1 loud beep
I downloaded the Prusa 2.1.8 package along with the 3.3.1 firmware for my Prusa Mk2.5. After upgrading Slic3r, I tried updating the firmware on my printer using the tool in Slic3r.
At the end of the update the printer started making a loud beeping noise and the display was full of square blocks. I assumed that there was a corruption in the firmware file so I downloaded the file again (double checking it was the correct file). I got the beeps again when I updated the firmware.
I went back to firmware 3.1.4 which is what I had on before and the printer is working fine again, but I'd like to go to the latest firmware release.
Does anybody know what is happening?
Rob
Re: Mk2.5 Firmware 3.3.1 loud beep
did you choose the correct version of 3.3.1?
both mk3 and mk2.5 use 3.3,1, but there may be minor differences
for instance my mk3 LCD failed, I tried to use a mk2 LCD but I get immediate TMC Driver overtemp errors, when the mk2 LCD is attached!
Went through the process again and it worked so I think I must have been selecting the incorrect rambo file without realising.
Rob
RE: Mk2.5 Firmware 3.3.1 loud beep
I am also having the one long beep issue. I've tried all the items above.
Can someone help me with a factory reset? I've seen the "push dial and X" method. It doesn't work.
Any help would be greatly appreciated.
