Mk2 heatbed cover replacement options?
Erik Hansen
(@erik-hansen)
Hi everyone, it's my first time posting here.
I picked up a 2nd hand Prusa i3 Mk2 (I'm told it was upgraded to Mk2.5s) and the heatbed PEI cover is gouged in a few places. The replacement PEI adhesive sheet is pretty expensive directly from Prusa. Are there any other recommendations for alternatives? I've been printing fine so far as long as I avoid the damaged sections.
Thanks!
Posted : 07/10/2025 7:59 am
That sheet is worn out.  What is the other side like?
Replacing the sticker is ... tricky so buying a replacement sheet is probably the best idea, by all means get the stickers as a project for another day when you have plenty of time.
With good maintenance and a little luck your printer should be ok for enough years to wear out another print sheet.
Posted : 07/10/2025 7:01 pm
