Mk2 heatbed cover replacement options?
Erik Hansen
(@erik-hansen)
Hi everyone, it's my first time posting here.
I picked up a 2nd hand Prusa i3 Mk2 (I'm told it was upgraded to Mk2.5s) and the heatbed PEI cover is gouged in a few places. The replacement PEI adhesive sheet is pretty expensive directly from Prusa. Are there any other recommendations for alternatives? I've been printing fine so far as long as I avoid the damaged sections.
Thanks!
Posted : 07/10/2025 7:59 am
Erik Hansen
(@erik-hansen)
OK, so according to the upgrade instructions here, I only have a MK2s, and not the 2.5s.
I'll probably just pay for the parts to do the full upgrade to 2.5s (3s) which should solve my problem long-term.
Posted : 07/10/2025 2:07 pm
That sheet is worn out.  What is the other side like?
Replacing the sticker is ... tricky so buying a replacement sheet is probably the best idea, by all means get the stickers as a project for another day when you have plenty of time.
With good maintenance and a little luck your printer should be ok for enough years to wear out another print sheet.
Posted : 07/10/2025 7:01 pm
Erik Hansen
(@erik-hansen)
RE: Mk2 heatbed cover replacement options?
Posted by: @diem
Other side?  There is only one side with the adhesive sheet.  The replacement adhesive sheet is only about 8 GBP, but the Prusa shipping to the UK costs more than the adhesive sheet.
This heatbed is the original non-magnetic one.  I'm seriously considering buying a load of magnets to glue to the underside of the heatbed, then switch to a magnetic steel dual-sided plate to print on.  Definitely the cheapest option.
Posted : 07/10/2025 7:12 pm
