“MK2.5S XYZ calibration fails after firmware update
Grev
 Grev
(@grev)
Hi All,
I updated my MK2.5S (MK52 bed) to firmware 3.14.1-8237
Printer homes but XYZ calibration fails with: “Calibration failed. Check axes and run again.” When I manually line up the PINDA so it is over the hashed circles it is ~15 mm offset in X from the x end stop switch. Y-axis and PINDA height (~1 mm above nozzle) are correct.
Has anyone seen this with the latest firmware?
Should I adjust the X-endstop/extruder mount temporarily, or is there a firmware/EEPROM fix?
thanks
Opublikowany : 12/11/2025 11:49 pm
M Neudeck
(@m-neudeck)
RE: “MK2.5S XYZ calibration fails after firmware update
Did you solved this problem and what was the solution?
Opublikowany : 04/02/2026 6:52 pm
