MK2.5S X-Axis switch prevents using the full bed size.
Led
 Led
(@led)
Hi, I've recently discovered that after the last update from MK2.5 to MK2.5S I've lost use of the full bed size on the X-Axis.
I only recently discovered this since I don't usually have to use the full bed size, I'm only missing a few mm (3-4) on the left side (near the X-Axis switch).
This is not a software problem as the carriage with the endstop-block can't physically get any closer to the edge.
The only thing I can think of is that I must have an incorrect part somewhere, I did the upgrade following the manual as before, but I guess I must have missed a part replacement, I've checked the spares I kept from the upgrade and I did change the backplane, which was my initial worry.
I checked removing the endstop-block and the carriage can indeed come quite a bit closer, I could shave off the endstop-block, but I would like to know and fix what's actually wrong.
Any clues on what could be the mistake?
Anybody has the revisions on the parts I should have installed?
Respondido : 15/12/2019 1:40 pm
