MK2.5s filament sensor failed, How do I now configure my printer.
My filament sensor failed several months ago, and do not have a spare nor have I been able to find a replacement.
This would not normally be a problem since the printer continues to work just fine without the sensor, however, the printer started having a problem doing the bed leveling tests. While this is not related to the filament sensor, trying to re-run the wizard to aid in fixing the new problem I find that I now can't get passed the setup wizard because it has detected the filament sensor is not responding and won't go any further.
What should I do now?
Publié : 26/04/2020 3:19 pm
