MK2.5 Upgrade; Rotating Knob causes LCD to white screen and reset.
Datsun
(@datsun)
As the title states, any time I rotate the rotary knob, the LCD gets 2 two 4 white bars, then resets to the boot screen, then loads the home screen (like normal). I can click the knob and it will go into the menu selection, but as soon as I rotate the knob, it restarts.
This is on a MK2 that I just upgraded to a MK2.5, I've tried flashing 3.6.0 and 3.7.0 firmwares and I get the same issue.
Thanks for any help.
Publié : 12/05/2019 5:42 pm
Datsun
(@datsun)
RE: MK2.5 Upgrade; Rotating Knob causes LCD to white screen and reset.
Solved. I had the double striped ribbon cable's orientation backwards. Had to go back and reference the old MK2 manual to see that step.
Publié : 12/05/2019 5:49 pm
landon.e2
(@landon-e2)
which double striped ribon cable?  I’m not seeing it?
Publié : 18/01/2020 2:28 am
