LCD screen only showing rectangles?
I got the mk2 to mk2.5s upgrade and just finished putting it together. But when trying to flash the firmware, the LCD screen just shows rectangles, even though I flashed the correct firmware. I attached an image of the screen...any ideas as to why it isn't working? I have checked the wires, everything is plugged in. The screen was working before the firmware update. Thanks so much for the help!
This topic was modified 5 years temu by 3DPC
Opublikowany : 23/12/2020 3:01 am
RE: LCD screen only showing rectangles?
I upgraded firmware, and downgraded it, no-joy with either. Finally broke down and ordered a replacement screen from Prusa, now it works well.
No clue as to what happened.
Opublikowany : 05/06/2021 1:39 am
firmware
make sure you flash the correct file... i made the mistake of selecting the wrong one and the screen went black
should be 13a not the ones on top
Opublikowany : 08/10/2021 8:12 pm
