Identify rambo?
ronyd
(@ronyd)
Identify rambo?
How do i identify rambo 1 or 2 in itder to pick the correct siftware update?
Publié : 07/01/2023 3:06 pm
Hello
(@hello)
RE: Identify rambo?
It's what mk you have not the board when you have if you still have original bed it says on there or just take pictur of your printer
Publié : 07/01/2023 7:44 pm
ronyd
(@ronyd)
RE: Identify rambo?
oh daaaah..  Sorry MK2.5S
thankx
Ron
Posted by: @hello
Publié : 07/01/2023 7:47 pm
Hello
(@hello)
RE: Identify rambo?
So you need MK2.5S software
Publié : 07/01/2023 7:49 pm
ronyd
(@ronyd)
RE: Identify rambo?
Msg coming up on the display to do an update 3.10.
Publié : 07/01/2023 7:56 pm
Hello
(@hello)
RE: Identify rambo?
Do you want to know how to update it I caRnt see image probably quite small
Publié : 07/01/2023 7:58 pm
Hello
(@hello)
RE: Identify rambo?
Oh I see how olds your printer
Publié : 07/01/2023 8:00 pm
ronyd
(@ronyd)
RE: Identify rambo?
I assume 2107.  Was upgraded  from orginal 2.0  to 2.5
Posted by: @hello
Publié : 07/01/2023 8:02 pm
Hello
(@hello)
RE: Identify rambo?
I think you will have 10a then the slicer won't let you download wrong firmware any way but if it used to be mk2 then I think 10a
Publié : 07/01/2023 8:04 pm
Hello
(@hello)
RE: Identify rambo?
Did it work
Publié : 07/01/2023 8:38 pm
ronyd
(@ronyd)
RE: Identify rambo?
Have not yet.  Had to replace the hot-end assembly.  Running a print now to make sure everything is good before installing firmware.  thankx
Publié : 08/01/2023 5:59 pm
Bonesteel
(@bonesteel)
RE: Identify rambo?
There's a file (PDF) in the download entitled how to choose firmware. It also has photos of the boards.
Publié : 10/01/2023 1:29 pm
ronyd
(@ronyd)
RE: Identify rambo?
Great thankx 👍
Publié : 10/01/2023 4:41 pm
ronyd
(@ronyd)
RE: Identify rambo?
Haven’t found the pdf.  Where is it specifically ?
Posted by: @bonesteel
Publié : 10/01/2023 5:03 pm
ronyd
(@ronyd)
RE: Identify rambo?
Aaah you were referring to github?
thankx
Posted by: @ronyd
Publié : 10/01/2023 5:18 pm
Bonesteel
(@bonesteel)
RE: Identify rambo?
Go to the download page here:
https://help.prusa3d.com/downloads
Download the firmware for the 2.5S (see pic attached) 3.11.0. You'll get a .zip file. Expand that and you'll see it. See second file attached.
Jon
Publié : 10/01/2023 5:26 pm
