Heated Bed Temperature Jumpy: 28deg --> 60deg, back and forth
any ideas would be appreciated. I didn't have much luck with my printer (didn't assemble it for a long time, after assembly, MMU1 keeps failing, never worked, now after maybe 6 months of low usage the heated bed is giving issues. I built many MANY printers.
Room temp (default heated bed temp value): 28degC
Heated bed temp (PLA): 60degC
What happens is the temp reading is intermittent, ie. 28degC, then 60degC, then 28degC, back to 60 degC, you get the idea.
Thermistor seems fine, wiring seems fine. Plugged wires in/out many times.
What can I do next? Change main board? Change thermistor?
Postato : 01/06/2019 4:56 pm
