Heatbed: Misalignment of center mounting points
alexander.f5
(@alexander-f5)
During my upgrade to 2.5, I found out, that the center mounting points of the headbed didn't align straight with the holes of the frame.
I started with the corners, looking like this:
When I wanted to mount the belt holder in the center, the screws didn't want to go in.
As you can see, the are a good milimeter from where they should be.
So I drilled the holes wider, wiggeling my drill around to get a more slotted hole.
not very professional, I know 🙄
Did anyone else have this problem?
Opublikowany : 17/06/2018 8:12 pm
