Firmware 3.2.0-RC1 for Original Prusa i3 MK3 and MK2.5
marek.c3
(@marek-c3)
UPDATE: there is a newer version available! More here https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f44/firmware-3-2-0-rc2-for-original-prusa-i3-mk2-5-t16998.html
Hi there,
new version of firmware 3.1.4-RC1 for MK3 and MK2.5 is out! Note this is a test build for advanced users 😉
What is new:
MK3:
- linear advance
- new xyz calibration
- filament sensor function improved
- safety timer
- G-codes for setting temperature correction
- extruder linearity correction
- stealth mode for Z axis
MK2.5:
- linear advance
- safety timer
Supported printers:
This firmware supports Original Prusa i3 MK3 and MK2.5
Download link and description: https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.2.0-RC1
Firmware flashing guide: http://manual.prusa3d.com/Guide/Upgrading+firmware+v1.2/66?lang=en
Please report any bug here: https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Respondido : 13/04/2018 8:46 pm
devilhunter
(@devilhunter)
Re: Firmware 3.2.0-RC1 for Original Prusa i3 MK3 and MK2.5
Question:
What is "Stealth mode for Z axis (MK3)"? Less motor current on the Z axis?
Respondido : 14/04/2018 12:39 pm
GertL
(@gertl)
Literally all MK2s with the latest firmware are unable to print via OctoPrint.
Have worked for me, i was using the 3.1.0 version.
Now I'm on MK2.5, v3.1.4 works there also with OctoPrint.
Gert
Respondido : 14/04/2018 1:26 pm
devilhunter
(@devilhunter)
Yeah, a firmware downgrade to 3.0.10 or 3.0.9 is the only way to print via OctoPrint on the MK2
It's been this way for 6 months now.
Respondido : 14/04/2018 3:28 pm
GertL
(@gertl)
I don't know what issue you have but this solved the issue i had way back.
https://shop.prusa3d.com/forum/software-f13/checksum-mismatch-t6214.html#p43543
Gert
Respondido : 14/04/2018 3:36 pm
Netnac
(@netnac)
OctoPrint is working flawlessly on my MK2 using 3.1.0 firmware. I never had any issues with LA and 20H+ prints. I'm also using a Pi Zero W for months now without issue, same quality than a Pi3. Remove the Octopi plugins you are not using, keep things simple.
Also, make sure you are using a good quality MicroSD card (i'm using SanDisk Ultra) and a good power supply 2A +. Don't expect good results with an underpowered pi using a poor quality card. This is valid with any Rasperry Pi in any application.
Respondido : 14/04/2018 6:30 pm
devilhunter
(@devilhunter)
Very weird.
I have two MK2s with this issue, one at work connected to a PC running barebones OctoPrint, one at home running IctoPrint on a Pi2 with quite a few addons.
Both machines are on 3.1.0, both have the 'send additional OK for resend requests' ticked, both randomly stop midprint, sometimes even at the first layer.
When i downgrade both firmwares on the printers to 3.0.9, everything's A-OK, and they never stop printing midprint.
From what i can read in the changelogs, 3.1.0 introduced Linear Advance, and this randomly overloads the Rx Buffer on the board when printing over USB.
Prusa made a clean cut on the MK2 branch and concentrated only on the MK3 branch, since the MK3 had a LOT more problems with the firmware than the MK2 had. (this was around December last year)
LA was disabled on the 3.1.x betas until they rewrote a good chunk of code to avoid buffer problems according to a post made by Josef himself.
The MK2 was left were it was, until they merged the MK2/MK2.5/MK3 firmwares a couple of days ago. (Still no 3.2.0 for the MK2 though)
Respondido : 14/04/2018 11:14 pm
motocoder
(@motocoder)
I installed 3.2.0-RC1 on my MK3 and then did a full factory reset. Now it won't complete X-Y calibration.
Respondido : 20/04/2018 11:27 pm
