filament sensor N/A help
ian.k2
(@ian-k2)
So I have upgraded my MK2 to mk2.5.
When I switched it on it started and then gave error preheat nozzle. I checked all the cables and realised the filament sensor was incorrectly thinking I was trying to feed filament. Which I was not.
I switched it off and checked cables and now it is not giving the error.
However, going into settings the Filament sensor is reading N/A. The cable is on the bottom pins as stated.
Any help you guys can give - is it a duff sensor?
Opublikowany : 02/04/2018 10:44 pm
ian.k2
(@ian-k2)
Re: filament sensor N/A help
Ok will leave this for anyone who has the same issue.
I have 2 x Mk2.5 upgrade kits so i tested the sensor with my other kit.
That works fine so i have a bad sensor so will contact Prusa support.
Opublikowany : 02/04/2018 11:20 pm
carolyn.l2
(@carolyn-l2)
Is that what it means? Because "ERROR: PREHEAT THE NOZZLE!" is starting to happen on my MK3.
Opublikowany : 07/05/2018 1:07 am
