Extruder correctly finds home, but then fails at begining of XYZ calibration with "Calibration failed, check axes"
Slowpoke
(@slowpoke)
This is a i3 MK2S upgraded to a MK2.5S (with metal plate)
Firmware:
I tried both 3.8.1 and 3.13.2  same results
When I select Calibration | Auto Home,  the PINDA sensor is very close to centered in the target.
When I select Calibrate XYZ, after setting the top Z, the extruder comes down well left of the target (perhaps that's normal I'm not sure) but then stops and throws error  "Calibration failed, check axes"
The PINDA sensor light turns off just as the extruder approaches the table, but then it stops and throws the error.
Not sure what to do next?
Posted : 20/11/2023 7:18 pm
