Endstop checks before printing
I found a strange behavior. I managed to miss align a metal sheet and that caused that sheet blocked the Y axis and the plate could not move. I started the print and after the initial autohome the 9 point calibration started even when the Y axis didn't hit the end stop. There should be some protection against this am I right? The before print calibration should verify, that both endpoints were hit. The print started even with Y axis in totally incorrect position.
Same happened with X axis, when I forgot tighten the screw from extruder idler. This screw caused, that the extruder didn't reach the endpoint.
I have the 3.5.1 firmware.
Vasek
Publié : 21/01/2019 7:25 pm
