elapsed printing time not shown correctly on screen
I recently upgraded my MK2 to a MK2.5 and have since had issues with the display not showing the correct elapsed time (see attached picture). Does anyone have an ides on why this is? the rest of the UI seems to work fine.
Re: elapsed printing time not shown correctly on screen
It's showing time remaining...
That is one long print.
Joan
Every single print I do shows that same time. None of my prints take that long and the display never changes.
This does work on my mk3, only my mk2.5 shows this bogus time. (It's the same exact time the first user posted as well)
On my mk2.5 it looks exactly like yours. This is an exclusive mk2.5 issue (or feature)
Currently only the MK3 recognizes g-code M73.
You can uncheck the box "supports remaining times" in slic3r , so you see the elapsed time.
I filed https://github.com/prusa3d/Prusa-Firmware/issues/1120
It runs the time remaining on my Mk2.5 just fine. I am running 3.4.0 rc2 with Slic3r 1.41.0
Anything can be made better
https://www.myminifactory.com/users/Joe%20Prints
I even tried a full factory reset and get the same results.
I'm running firmware 3.3.1-845 and Slic3r-1.41.0+linux64
A fix has been committed to git and I would imagine will be in the next release.
Based on the fix I realized I was running in "silent" mode. If I switch to high power it prints the correct time left.
