Display Showing 2 Rows of Squares - Tried Replacing Cables and Flashing Firmware
erik.c9
(@erik-c9)
Hello everyone,
I am wondering if anyone has figured how to solve the issue with the display showing 2 rows of squares.
I have tried to fix this problem by:
1) Flashing the firmware
2) Replacing the two ribbon cables (I have gone through 2 sets of cables with no success unfortunately)
3) Reseating the ribbon cable connections on the RAMBo and display PCBs
I have had brief moments with the LCD display working, but the LCD display would revert back to either gibberish or 2 rows of squares when I went to the next screen. This makes me think the issue could be with the LCD display PCB rather than the RAMBo board.
I am feeling a little stuck and would appreciate any help. The print quality on my Mk2.5 has been fantastic and would love to go back to printing cool things.
Postato : 20/10/2018 10:14 am
chris.p8
(@chris-p8)
Re: Display Showing 2 Rows of Squares - Tried Replacing Cables and Flashing Firmware
I have had this problem when building things and it was the LCD connections shorting sometimes?
Think you are correct and the problem is probably with the LCD display unit - easy check would be to try
someone else's display, I am in the SW of the UK if this is anywhere near you? (Exeter or Torquay)
LCD display panels are pretty inexpensive if you are handy with a soldering iron - a 20 character * 4 line
display (that Prusa uses (or it might be 16 characters * 4 lines, can't remember!) - is around 10 UKP - but
the PCB it is mounted on might have a short/bad connection and the LCD panel might be ok?
Think taking the panel off and using a magnifying glass to look at the PCB couldn't hurt, might show something obvious?
Perhaps ask Prusa for a circuit diagram? There is one for the Rambo board but haven't seen one for the LCD display
Regards
Chris
Postato : 31/10/2018 11:46 am
Speak to Prusa Chat,
https://shop.prusa3d.com/en/#_ga=2.150945526.1338715520.1540983084-1615412680.1538869085&_gac=1.216796706.1539019667.EAIaIQobChMIir2n_K733QIVh-F3Ch1nPAohEAAYASAAEgKz0vD_BwE
there is usually an orange chat box in the bottom right hand corner of the page that I have linked to, above... however, today when I looked the chat box was white... maybe it's a winter thing...
good luck,
Joan
Postato : 31/10/2018 11:54 am
Esteban Ponguillo
(@esteban-ponguillo)
RE: Display Showing 2 Rows of Squares - Tried Replacing Cables and Flashing Firmware
I have the same problem, if anyone knows how to fix it please post.
Postato : 25/10/2022 10:39 pm
