XYZ calibration fault on last point
Hi, after upgrading firmware to 3.9.3-3556 I am not possible to go throu XYZ calibration. After the fourth point it stops with error message saing to read the manual. I have MK2.5S. What now, downgrade?
Opublikowany : 26/01/2021 8:23 am
Topic starter
answered:
RE: XYZ calibration fault on last point
After dowgrade to 3.9.2 it works again.
Opublikowany : 26/01/2021 10:18 am
Same....using PindaV2, superpinda is off
Fail at Point 3 or 4
Opublikowany : 07/02/2021 1:25 pm
Same issue here. Maybe I need to downgrade too...
Double checked everything, auto=home is perfect, everything is square and all points reachable manually with perfect parallel height.
Opublikowany : 17/04/2021 6:56 pm
