Where is the 2.5S upgrade part list?
Hiro Protagonist
(@hiro-protagonist)
Ugh, I should have just ordered an extra kit when there still was a kit...
Where can I find the list of parts to order to do the 2S to 2.5S upgrade?  I do see that some things are out of stock, like the SuperPINDA of course. I can wait, but where do I get the exact list of parts?
Publié : 22/04/2021 5:59 am
RE: Where is the 2.5S upgrade part list?
If you look through the upgrade guide, it will tell you which parts are required.
https://help.prusa3d.com/en/guide/4-heatbed-assembly_51736
note there are both Mk2.5 to Mk2.5S upgrade and Mk2 to Mk2.5s upgrade sections, make sure you select the correct one!
Publié : 22/04/2021 9:33 am
Hiro Protagonist
(@hiro-protagonist)
Hmmm, so I have to scrape the whole guide? I swear that they said in a live stream that they'd supply a list when the kit was discontinued. Maybe I should go ask support. I'll post here if I get a useful reply.
Also, has anyone tried sourcing the parts from somewhere other than Prusa? 12V heatbed and PINDA are currently out of stock.
Publié : 22/04/2021 3:33 pm
Hiro Protagonist
(@hiro-protagonist)
Support replied with this list. Doesn't included fasteners, which I don't think Prusa sells for this purpose, so you'd have to find them locally. If you have another Prusa which you built from kit, you may find a lot of small parts in your spares bag.
- Magnets (Large: 20 x 6 x 2 mm Small: 10 x 6 x 2 mm)
- Steel ball
- Bondtech gear set
- Hotend PTFE
- IR sensor
- IR sensor cable
- Noctua fan - SuperPINDA
- Heatbed MK52 12V (cables and thermsitor come with the bed in the e-shop)
- P.I.N.D.A. probe v-cable
- Left hotend fan v-cable
Publié : 22/04/2021 4:00 pm
I have a box of assorted fasteners for just such a purpose, ranging from 6mm long to 40mm long,
Please be aware that the square nuts and the hex nuts are 'thin' varieties
https://www.ebay.co.uk/itm/222404681983?var=521274421704&hash=item33c85a20ff:g:Sn4AAOSwOgdYnPJq
https://www.ebay.co.uk/itm/224027369857?var=523217269382&hash=item3429126181:g:oacAAOSwOXBf7ZWP
I believe the filament sensor uses a 2mm cap screw, the extruded frame uses
and the heatbed uses 3mm dia countersink screws
Publié : 22/04/2021 5:27 pm
gizmatron
(@gizmatron)
question related to this as i also missed the kits being discontinued and too late now. So as the only thing i really want is the magnetic bed and its a straight swap onto my mk2S (plus its available) can i just fit it and re-calibrate the xyz axis to compensate for the metal sheet thickness? I'm sure I read the calibration had to be done with just the heated bed and no sheet so is that then compensated for in the updated firmware? or can i just make it work on a straight mk2S?
Publié : 10/05/2021 7:27 pm
