Upgrading MK2S to MK2.5S X-end question
Edy195
(@edy195)
Yo!
I tried to find answer from older topics but I couldn't find.
So here goes:
When I upgrade MK2S to MK2.5S can I use "X-axis motor end" and "end idler" from MK3S?
Because when I am looking an upgrading manual ( https://manual.prusa3d.com/Guide/3.+E-axis+assembly/1073?lang=en )
Picture shows @Step 49 part that is not included in original MK2.5 or MK2.5S upgrade part packs.
I get that these are probably just re used pictures from MK3(S) manual.
But that tension system looks better so I might as well print those before starting upgrading...
If those fit.
Hope you can help! 😀
Opublikowany : 20/03/2019 5:14 pm
Edy195
(@edy195)
Re: Upgrading MK2S to MK2.5S X-end question
And I'll answer my own question. The answer is NO!
End switch needs mounting place. 🙄
Opublikowany : 20/03/2019 6:38 pm
Spradlinb
(@spradlinb)
I ran across the same issue. Luckily, someone else has already fixed that up for us:
https://www.thingiverse.com/thing:2928824
I've been using that on my own printer for a few weeks now, no issues at all. Definitely nice to have the option to change the tension like the MK3!
Opublikowany : 26/03/2019 8:01 pm
Robert Eliason
(@robert-eliason)
Good to know, I'm planning on installing this upgrade when I get the MK2.5S Kit 🙂
Opublikowany : 02/04/2019 10:40 am
