Slic3r Prusa Edition 1.41.2-FINAL
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Hi guys,
brand new Slic3r Prusa Edition 1.41.2 is out! This is a final stable release recommended to all users 😉
What is new?
This release is focused on performance improvements and bug fixes:
Improved OpenGL rendering performance on OSX Mojave #1250.
Fixed some crashes when slicing multi-material prints #1368, #1415.
Fixed invalid extruder assignment after switching from a multi-material printer profile to a single-material printer profile.
Supported printers:
- Original Prusa i3 MK3
- Original Prusa i3 MK3 Multi Material 2.0
- Original Prusa i3 MK2.5
- Original Prusa i3 MK2.5 Multi Material 2.0 (new)
- Original Prusa i3 MK2/S
- Original Prusa i3 MK2/S Multi Material 1.0
Download link:
https://www.prusa3d.com/drivers
Previous releases:
Slic3r Prusa Edition 1.41.2-RC https://github.com/prusa3d/Slic3r/releases/tag/version_1.41.2-rc
Please report any bug here:
https://github.com/prusa3d/Slic3r/issues
We look forward to your feedback!
Assembly manuals
/ Knowledge Base
Opublikowany : 24/11/2018 10:56 pm
lowenski
(@lowenski)
Re: Slic3r Prusa Edition 1.41.2-FINAL
Can someone please add an Icon to the appimage installer for Linux Cura can why not Slic3r?
Opublikowany : 27/11/2018 3:56 am
Mikko
(@mikko)
Thanks for developing something new every time 🙂
My problem with this version is that the print presets disappear. After (re)install the FINE, OPTIMUM, FAST etc. options are there, when I define a new print with some modifications, they are suddenly no more. Only -default- setting shows up. Sorry, didn't make note which specific settings change might have done this. This is annoying me a lot. Only a reinstall restores these presets and then they go away again, with my first work. The config folder shows there are ini files in the print folder, but none of these showing up in the drop down. What am I not getting here?
Opublikowany : 28/11/2018 6:09 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
I don't know. Most likely your Slic3r configuration is damaged for an unknown reason.
Would you please send us the content of your Slic3rPE directory?
Opublikowany : 04/12/2018 1:01 pm
ManelTo
(@manelto)
One question about the other program from Prusa... is Prusacontrol dead? 😐 The last actualization is from november'17
Sorry for my poor English. I try to do my best.
Opublikowany : 21/12/2018 8:34 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
PrusaControl's features are being integrated into Slic3r. Stay tuned for the upcoming Slic3r PE 1.42 alpha.
Opublikowany : 21/12/2018 9:16 am
rob.m17
(@rob-m17)
What are the system requirements for minimum OS X level on Mac to run Slic3r PE?
Opublikowany : 25/01/2019 8:51 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
OSX Maveric
Opublikowany : 29/01/2019 7:45 pm
