Old slicer files for MK 2.5 and MK 3 to 2.5S and 3S
Carl A
(@carl-a)
I have old 2.5 and 3 files. Is there a way to convert them for use on the 2.5S and/or 3S? I know that when I put a 2.5 file in a 2.5S printer (for example) I get a message that says it was not sliced for this printer, do I want to continue. It it will work, that is fine but if not and there is no way to convert the file, then I have to go back an slice the file(s)  again.
Solution????
Publié : 08/10/2020 11:41 pm
adrianj
(@adrianj-3)
RE: Old slicer files for MK 2.5 and MK 3 to 2.5S and 3S
The few I have tried from a Mk2 to Mk2.5S have worked.  But since its a pretty easy process to re-slice, provided you have an .STL or equivalent, I dont see that you should need to.  The newer slicers do a lot better than the old ones.
Publié : 11/10/2020 2:46 am
