MK2.5 plain spring steel bed sheets original with cut outs
Dan
 Dan
(@dan-2)
It would be good to know when plain spring steel sheets are available or does it make sense to find a supplier based on the sketch file?
Respondido : 23/03/2018 9:32 am
Kris
 Kris
(@kris-4)
Re: MK2.5 plain spring steel bed sheets original with cut outs
If you are looking for just blank spring steel sheets to put your own surface on, BuildTak came out with ones that are sized perfectly for the MK52 heat bed.. The notch is different, but it still centers on the two screws perfectly. Thank Chris over at the facebook group =)
I have a pair with BuildTak, GekoTek, and PEI on alternate sides.
https://www.buildtak.com/product/flexplate/
If the drop down does not show a size option with (PrusaMK3), check that you are on the .com store and didn't get redirected.. I read on the facebook forum that some folks cant find it and that seems to be the reason. It's $25 for the blank sheet, but it is so nice to be able to switch back and forth!
I would have happily given the money to Prusa, and I'll still buy their textured sheets when available.. but impatience is expensive =)
Respondido : 24/03/2018 11:14 pm
