MK2.5 re-print all printable parts minus the extruder parts. Can I use the MK2S printable parts?
vancity.exe
(@vancity-exe)
So I've had my Prusa for awhile now and parts are starting to crack. I want to reprint everything except the extruder parts as I have the Bondtech Extruder. I found these parts thanks to someone posting on this sub Prusa MK2S - Parts but when I look at the MK2.5 - Parts (My Printer) all there is, is Extruder parts because it was an upgrade I suppose.
So can I get away with using the MK2S parts or just use the MK2 parts?
Also as a side note why is Prusa making it so difficult for old customers to find these printed files? Most ppl wont find them as they're not listed anywhere. Im on the waiting list for the XL and I hope I can use it as long or longer than I've use my MK2.
Best Answer by Milos V.:
There were no changes from 2S to 2.5 other in the extruder parts except for the Rambo electronics box. I believe the new box has some easier way to assemble / dissasemble. Usually, this is not anything you will probabably need to change or at least to print in advance. You can print anytime it fails. Also there was a small change in the heated bed cable cover (the small plastic part covering the cables comming to heated bed).
Not sure if this was already for 2.5 or to 2.5S.
Anyhow, if you are not interested in extruder parts, you can simply use the MK2S parts.
Respondido : 20/11/2021 9:15 pm
Milos V.
(@milos-v)
RE: MK2.5 re-print all printable parts minus the extruder parts. Can I use the MK2S printable parts?
Respondido : 21/11/2021 9:54 am
1 les gusta
