Firmware 3.2.0 for Original Prusa i3 MK2.5
marek.c3
(@marek-c3)
UPDATE: There is a new version, more here https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f44/firmware-3-2-1-for-original-prusa-i3-mk2-5-t18475.html
Hi there,
new (final) version of firmware 3.2.0 for MK2.5 is out!
What is new for MK2.5:
- linear advance
- filament sensor function improved
- safety timer
- G-codes for setting temperature correction
- Rambo 1.0 support
- temperature calibration improved
Supported printers:
This firmware supports Original Prusa i3 MK2.5
Download link and description:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.2.0
Firmware flashing guide:
http://manual.prusa3d.com/Guide/Upgrading+firmware+v1.2/66?lang=en
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Opublikowany : 10/05/2018 11:06 am
Qweris
(@qweris)
Re: Firmware 3.2.0 for Original Prusa i3 MK2.5
❗ Hi!
I'm experiencing a few bug with the new Firmware .
First, the selftest. As you can see on the video linked below it tells me that the fan isn't working. Both fans are working perfectly - I verified this with the selftest on Firmware 3.1.0.
https://photos.app.goo.gl/ugxvDM9icfcadSkp1
Secondly, the bed mesh calibration does not work because the bed moves to far inwards so the PINDA probe is not alight with the spots on the bed. This can be seen at 00:03 - 00:04 in the video linked below. Because the pinda probe is not perfectly above the marked spot in the bed it hits the bed on one sit and hovers 3mm above it on the other side.
https://photos.app.goo.gl/Oqt9LTwZrTvaeo4C3
I've got a MK2.5
- Mark
Opublikowany : 15/05/2018 9:53 pm
Romek
(@romek)
So why You are writing this on MK2.5 forum? Your bed and fan are MK2S?
Opublikowany : 16/05/2018 12:32 pm
Hi Mark.
your pictures seem to show a Mk2 printer,
the Mk2 printer does not have a noctua extruder fan with integral tachometer,
which is why the fan test is not working,
and it looks like you still have a Mk2 heatbed, which has different locations for the sense positions,
so you are unlikely to get good results from Mk2.5 firmware
Opublikowany : 16/05/2018 12:57 pm
Qweris
(@qweris)
I'm sorry, you are right! ooopss....
Opublikowany : 19/05/2018 12:44 pm
