Firmware 3.7.1-FINAL for Original Prusa i3 MK2.5S & MK2.5
Jakub Dolezal
(@jakub-dolezal)
Member Admin
WARNING: Note that MK3S, MK3, MK2.5S and MK2.5 are different printers! Each has its own firmware file!!!
Hi guys,
this is a testing version of the firmware recommended to experienced users only 😎
What is new?
  • Rambo board overheating fix
  • Enabled watchdog for MK2.5S & MK2.5
  • Octoprint MMU load failed fix
  • Bed preheat error fix
  • SPI flash error is not blocking the printer anymore
  • IR-sensor self-test fail message added
  • Menu items text overflowing fix
  • Linearity correction not saved to EEPROM fix
Watchdog fix
In the firmware version 3.7.1-FINAL we added on MK2.5 and MK2.5S printers a watchdog for better safety. In firmware 3.7.1-RC1 the watchdog was only added to MK2.5.
Rambo board overheating fix:
In the firmware version 3.5.2 and higher, we have increased the PWM frequency to reduce noise from the new PSU (black case). In some cases, the Rambo board overheated. We have now reduced this frequency to 32 Hz so that both, old PSU (silver case) and new PSU (black case) are quiet enough and not overheating.
Octoprint MMU load failed fix:
On the older firmware version for MK2.5S and MK3S printers printer doesn't pause after MMU2 load error when printing from Octoprint. The new behaviour is, that when printing from Octoprint T-command failure block execution of following commands. The printer doesn't respond "OK" to Octoprint until T-command is successfully finished. There is blocking message "MMU load failed" on the status screen and each time printer knob is pushed, printer retries filament load to nozzle move.#1652
Bed preheat error fix:
This release fixes false detection of bed preheat error. Minimum temperature rise slope criterion in the time domain was relaxed.
SPI flash error is not blocking the printer anymore:
MK3S & MK3 error message "External SPI flash W25X20CL is not responding." is no more completely blocking printer operation. Now it is shown during splash screen and it is possible to use printer, only available language is English.
Other:
- Enabled watchdog for MK2.5S & MK2.5
- Translation corrections
- IR-sensor self-test fail message added
- Menu items text overflowing fix
- Linearity correction not saved to EEPROM fix
Supported printers:
Original Prusa i3 MK3S MMU2S
Original Prusa i3 MK3 MMU2
Original Prusa i3 MK2.5S MMU2S
Original Prusa i3 MK2.5 MMU2
Download link:
prusa3d.com/drivers
Firmware flashing guide:
manual.prusa3d.com/Guide/Upgrading+the+firmware/66
Please report any bug here:
github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Napsal : 14/05/2019 7:52 am
Gt6k
 Gt6k
(@gt6k)
RE: Firmware 3.7.1-FINAL for Original Prusa i3 MK2.5S & MK2.5
This doesn't seem to have fixed the bed mintemp error on startup for me.  With 20C at start up the bed heats to 28C in about 30secs then gives mintemp, every time.  I reset it and it then heats and runs perfectly.
Napsal : 19/05/2019 7:57 am
1 lidem se líbí
Tiger3DPrinting
(@tiger3dprinting)
can you explain in more detail what exactly watchdog is?
Napsal : 20/05/2019 12:21 am
1 lidem se líbí
sopis
(@sopis)
I too am interested in the watchdog - what is that? thanks
Napsal : 22/05/2019 11:37 am
Peter C
(@peter-c-2)
I have the same issue as ian-h2.  I too have to do a reset and then continue with the print.
This post was modified před 7 years by Peter C
Napsal : 03/06/2019 2:07 am
david.w18
(@david-w18)
I am seeing this problem too. Starting temperature today was below 20 degrees (nearly mid summer here in England). It got to 30 before giving the Bed mintemp error. Reset and try again and second time it heats ok.
Napsal : 14/06/2019 11:48 am
