"File incomplete. Continue anyway?"
Chuck76
(@chuck76)
I have a large part that is throwing the error "File incomplete. Continue anyway?" and need some expert help.  The part was designed in Fusion 360 and converted to g-code using Prusa Slicer.  Any help would be appreciated.
Publié : 22/08/2022 9:13 pm
Chuck76
(@chuck76)
RE: "File incomplete. Continue anyway?"
This is a link to the G-code - https://www.amazon.com/clouddrive/share/GhGc8JeSIUs5YzgFCmi6NzBIZEkBoRl3ouqLXpiW5D2
Publié : 22/08/2022 9:35 pm
It's telling you that the file is corrupt or incomplete.  The usual reason is that when copying the file to the SD you didn't allow enough time for a large file to complete transfer before removing it ...  Or you didn't follow the proper unmounting procedure.
Go back and recopy.
Publié : 22/08/2022 10:42 pm
Chuck76
(@chuck76)
Thanks for the reply.  The slicer gives the message that the disk was dismount.  I tried creating a g-code from a small piece and got the same result when trying to print it.  I had purchased a new computer and installed Prusa Slicer, I must have a wrong setting.  I will look at the settings.
Chuck
Publié : 23/08/2022 12:24 am
Have you tried a different card?
Publié : 23/08/2022 8:14 am
Chuck76
(@chuck76)
I tried two different cards.  The issue is with the settings in Prusa Slicer.  I installed Cura and the part is printing now with no issues.
Publié : 23/08/2022 4:27 pm
Strange that you should be the only one reporting it - have you been modifying 'End G-code' in Printer Settings?
Publié : 23/08/2022 5:26 pm
