Extruder moves too far right during calibration.
Jerry Siegel
(@jerry-siegel)
During any of the calibrations my extruder moves too far to the right after finding cal. point 1 OK. And I have to stop the calibration. No error messages as I stop the calibrations before they damaged the bed.
MK2.5S
New Rambo board
Passes self test
Assembly has been checked, belts checked
Tried but did not solve issue:
Firmware 3.10 and 3.8
Factory reset
Checks:
Self test - passed
XYZ calibration - failed
What else can I try?
TIA
Jerry
Opublikowany : 04/08/2021 9:35 pm
If a factory reset doesn't help take it to Prusa support:
For support: Log into your Eshop account, navigate to support and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Opublikowany : 04/08/2021 10:58 pm
Jerry Siegel
(@jerry-siegel)
Live Help=No Help
No help. I spent 4.5 hours on live chat. But they could not resolve the problem. Said they would "take it to the team" and get back to me this week. 🙁
Opublikowany : 07/08/2021 6:10 pm
pictures might help1
abstract thought...
is the X motor pulley 16 tooth? or 20 tooth?
20 tooth would put you off the end of the bed.
Opublikowany : 07/08/2021 7:37 pm
Jerry Siegel
(@jerry-siegel)
Hmm...
It’s the same pulley that has been on there for years. The board was replaced before, with this same board and worked fine until the LCD output failed. But I’ll check, just to be sure.
Attachment removed
Opublikowany : 07/08/2021 7:56 pm
Jerry Siegel
(@jerry-siegel)
It's a 20 tooth
So I checked and it is indeed a 20 tooth. But it worked fine before the Rambo board change. Doesn't make sense.
Opublikowany : 07/08/2021 9:16 pm
Jerry Siegel
(@jerry-siegel)
Solved!!!
So I swapped out the 20 tooth for a 16 tooth and now it passes XYZ calibration. But does not answer the question as to why it worked with the 20 tooth on the failed Rambo. The Universe is indeed a strange place. Thanks for the Help! 🙂
Opublikowany : 07/08/2021 10:11 pm
RE: Solved!!!
Something may have gone wrong during the firmware update. But I'm pleased that you could find the error 👍
wbr,
Karl
Opublikowany : 07/08/2021 10:29 pm
Teething Problems!
the world is full of Odd situations...
Glad it's solved
Joan
Opublikowany : 07/08/2021 10:48 pm
