y-axis flipped
michael.r
(@michael-r)
y-axis flipped
when I mirror in Prusa slicr the y axis I get a correct print...
what should I do to fix this problem?
Napsal : 25/03/2020 9:29 pm
kennd
(@kennd)
RE: y-axis flipped
Posted by: @michael-r
We need more in formation to be able to assist you.
  • Are you mirroring along the Y-axis? X-axis?
  • Correct print? Goal of all printing. 🙂  Typing error?
  • Ideally,  zip a copy of your .3mf project file and post it here.
  • Also post a picture showing the problem here.
  • Please provide more details explaining what you are expecting when mirroring, and what results you are getting.
I wish I could provide more, but I do not have enough information to even provide a WAG.
Kenn
Quality is the Journey, not the Destination. My limited prints->
Napsal : 25/03/2020 11:27 pm
michael.r
(@michael-r)
RE: y-axis flipped
@kennd
when i mirror the object in prusa slicer the print of typos is correct
see atached image where you see what happens when I print normal...
Napsal : 26/03/2020 12:28 am
kennd
(@kennd)
RE: y-axis flipped
Thanks for the picture.
I usually don't use text in my prints. And if I do, I make the text a separate object in my CAD program and do all my mirroring there. You are stuck.
Is there a reason you want to mirror that test object? Can you not just rotate it?
Napsal : 26/03/2020 12:43 am
kennd
(@kennd)
RE: y-axis flipped
I re-read your posts and I think I misunderstood. I thought the picture was of mirrored object.  My bad.  Either the author of the object wanted it that way ( bizarre ), or somewhere along the line it got mirrored, or I am still unsure of the issue. 😀
Please try to use descriptive filenames  describing the picture, like : 'non mirrored test object.jpg'
While people are willing to try and assist you, the more relevant information you provide in your first post, the better. I read your post several times and I was sure I understood it. Read it again this morning and now I am not so sure.
Napsal : 31/03/2020 5:15 pm
