XYZ Calibration Failed. Consult Manual
I can't find much on this error.
Completed the MK2.5 upgrade and ran the Wizard. At first the nozzle was ripping the paper, so I dropped the PINDA just a bit. Tried again and it started the 4 point calibration. It got through points 1 - 3 but maybe halfway through point 4 I get "XYZ Calibrations Failed. Please consult the manual." I did of course, and it doesn't say a whole lot. Basically "calibration points were found far from what should be expected." Hmmm..
So I tried a few more times, and one time it passed, I put on the steel sheet, and sure enough, the 9 point test passed, and I get "congratulations!!."
If something is borderline, I'd like to fix it, but don't know where to start. On the MK2S it always passed. Any ideas?
Opublikowany : 30/06/2018 7:53 am
