TroubleShooting NinjaFlex Print
TheSchemer
(@theschemer)
Good evening to all of you,
I am currently experiencing a problem with my flexible printing and more specifically with NinjaFlex.
Indeed, I have already had the opportunity to release beautiful prints with the settings that are fine (very slow speed, higher temperature...) however, for some time now, it has been impossible to release something correct. I have already questioned the settings and carried out a large serie of tests but nothing is done... So I ended up incriminating the filament (moisture recovery) and put it in the oven for a week at 50°C. Still without results. I therefore turn to you, the makers' community, to find out if you have already encountered this problem and the possible tricks to solve it. I now suspect the bondtech extruder, especially the alignment of the gears at the filament passage... Case to follow.
Attached are some pictures from my last impression.
Wishing you a good evening,
T.S.
Napsal : 16/12/2019 11:06 pm
