[Solved] Stuck on "searching bed calibration point 1 of 4"
JonasCA
(@jonasca)
Just upgraded my beloved MK2 with a kit from Prusa, however when doing the first calib it gets stuck in an endless loop on:
"Searching bed calibration point 1 of 4".
The printer makes small movements but does not proceed.
Posted : 30/01/2021 10:38 pm
Dave B
(@dave-b-3)
RE: Stuck on "searching bed calibration point 1 of 4"
How long have you been waiting?
I had a similar issue after upgrading my Mk3S -> Mk3S+ earlier today, but I let the calibration run.  It finally completed #1 after ~6 minutes, then moved onto point #2.  Each point took about 6 minutes to complete, but in the end it finished and the calibration succeeded.  After readjusting my z-level, my Mk3S(+!) is back in action.
I noticed that with the Super Pinda, the bed calibration seems to take longer due to slower z-axis movements during calibration/pre-print. Not sure if this is normal or not, but the self-tests are OK and it prints at the same speed it always has, so I'm not concerned.
This post was modified 5 years ago by Dave B
Posted : 31/01/2021 4:42 am
alainchiasson
(@alainchiasson)
I have the same issue - just finished my upgrad to the 2.5s kit ( from a 2) . I runs through the XYZ 4 point calibration, then says failed. Did you ever solve it ?
- Self tests passes.
- I check the PINDA probe with a screw driver (detects)
I have also tried with both - pinda and superPinda settings, It does the same. ( I'm prettysure I have a super PINDA - 3 wires - kit was ordered in the last batch ever - dec 2020)
Posted : 05/03/2021 4:25 am
Antonio
(@antonio)
Member Moderator
Posted by: @alainchiasson
Did you have any detail about the fail message?
I'm not an expert. Ma parlo anche italiano 😉
Posted : 06/03/2021 8:20 am
alainchiasson
(@alainchiasson)
@antonio-da-catania
It says "XYZ calibration failed. Please consult the manual" - I now realize this is different then the original problem from this thread.
I followed : https://help.prusa3d.com/en/article/xyz-calibration-mk3-mk3s-mk3s_112351/#troubleshooting-the-xyz-calibration ( linked to from  https://help.prusa3d.com/en/article/calibration-failed_2033/ )
Did a full reset, it failed again, twice. I then powered down, placed the PINDA in the right spot, powered up, and checked the sensor - I got odd readings ( it would flip at the midpoint on the X-Axis) , but when placing metal under it, it would flip to 1 (detecting).
The right hand was lower than the left ( by approximately 2 mm ).
I changed nothing after this, and retried the calibration - and it worked.
I hope future revisions would give more information on failures ( like stats on the screen ? I know there is not much there.)
Anyway. Thank you for replying. I am not sure what I have will help others, but its another place to find the links.
Posted : 06/03/2021 4:55 pm
Gigios
(@gigios)
I have the same problem, I have updated my MK3S with the MK3S + kit (for the moment I have only updated the superpinda to do some tests) and now I am in loop, every time I turn on the printer, it asks me to do a calibration, if I start xyz calibration, after more or less 24 minutes, I get the error message "XYZ calibration failed. Please consult the manual".
If I test the SuperPinda with a screw driver, I can see the led change the state (from ON to OFF) in a correct way.
I have also reset without success.
@antonio-da-catania, can you explain better your 'solution' please?
Posted : 04/05/2021 6:19 am
Antonio
(@antonio)
Member Moderator
@gigios
Hi, unfortunately I only have mk2.5s.
Not sure how to, but have you updated the firmware to the latest version?
Posted : 04/05/2021 10:40 am
Gigios
(@gigios)
@antonio-da-catania
Ciao, thanks for the answer. Yes, I'm using the firmware 3.9.3.
Posted : 04/05/2021 11:35 am
glovereric
(@glovereric)
I know this is an older post, but I had the same problem and it turned out to be the hotend was not properly seated - I could tell since it could rotate and sometimes came out. I disassembled the E-axis (kept the cabling intact, but took it apart enough to go back to step 12. Then when I closed up everything, the hot end could not move and it passed the initial self-test, calibrating now…
Posted : 07/08/2022 12:25 am
It can also happen if your pinda is too low.
Posted : 07/08/2022 3:07 pm
smohsin732
(@smohsin732)
If your printer is stuck on the "searching bed calibration point," it is likely that your Z-axis end-stop is not triggered. Check that your Z-axis end stop is triggered and adjust accordingly.
Posted : 01/09/2022 1:07 pm
Antonio
(@antonio)
Member Moderator
Posted by: @smohsin732
Z axis has no end stop. Pinda probe is the "end stop"
Posted : 01/09/2022 1:09 pm
