Smoother walls on a cylinder
Hi, I am trying to print a cylinder but when I do so I get visible 'flats' on the internal walls. Is this a function of the drawing package or the slicer? I use Fusion 360 and Prusa slicer. Thanks in advance.
Opublikowany : 30/01/2023 3:12 pm
RE: Smoother walls on a cylinder
Pictures would be very helpful (you can add them via "Add Media").
wbr,
Karl
Opublikowany : 30/01/2023 4:00 pm
Possibly the STL resolution is too low. The slicer should print round parts round. You have to select fine resolution when exporting STL from Fusion360.
wbr,
Karl
Opublikowany : 30/01/2023 6:36 pm
