Question on MK2S to MK2.5 to MK2.5S upgrade
Vinnces
(@vinnces)
So I have the MK2S running atm and it's working fine.  I ordered the MK2S to MK2.5 upgrade back in Nov of 2017.  Took a literal year, 11/19/2018 to be exact, for it to come.  At that time I was busy and so I just left the upgrade in the corner of my room.  So now I see they have a MK2.5 to MK2.5S upgrade in the shop.  I still haven't done the MK2S to MK2.5 upgrade yet.
So my question is if I order the MK2S to MK2.5S upgrade can I just upgrade my MK2S to MK2.5S skpping the MK2.5 part?
Veröffentlicht : 16/07/2020 8:14 am
RE: Question on MK2S to MK2.5 to MK2.5S upgrade
Yes!
use the new filament sensor setup!
be aware that there is a possibility of difficulty setting the filament sensor up , consider printing one of the Mk3S Filament Sensor Spacers, off thingiverse, before you start the upgrade, just in case
Consider adding a 5volt LED, to the filament sensor, as an immediate status indicator
here is My extruder with the cover missing, showing the location of the 5volt LED...
https://www.ebay.co.uk/itm/5-Volt-Red-LED-5mm-no-resistors-needed-Lot-of-10/121204355277?hash=item1c3857b0cd:g:kkgAAMXQgb1RLmui
Veröffentlicht : 16/07/2020 2:01 pm
Vinnces
(@vinnces)
So only the extruder parts that I need to print is different from the MK2.5?
Veröffentlicht : 16/07/2020 4:41 pm
