Question on MK2S to MK2.5 to MK2.5S upgrade
So I have the MK2S running atm and it's working fine. I ordered the MK2S to MK2.5 upgrade back in Nov of 2017. Took a literal year, 11/19/2018 to be exact, for it to come. At that time I was busy and so I just left the upgrade in the corner of my room. So now I see they have a MK2.5 to MK2.5S upgrade in the shop. I still haven't done the MK2S to MK2.5 upgrade yet.
So my question is if I order the MK2S to MK2.5S upgrade can I just upgrade my MK2S to MK2.5S skpping the MK2.5 part?
RE: Question on MK2S to MK2.5 to MK2.5S upgrade
Yes!
use the new filament sensor setup!
be aware that there is a possibility of difficulty setting the filament sensor up , consider printing one of the Mk3S Filament Sensor Spacers, off thingiverse, before you start the upgrade, just in case
Consider adding a 5volt LED, to the filament sensor, as an immediate status indicator
here is My extruder with the cover missing, showing the location of the 5volt LED...
So only the extruder parts that I need to print is different from the MK2.5?
