MK2.5S getting Bed Min Temp on cold startup
Gt6k
 Gt6k
(@gt6k)
Since doing the MK2.5S upgrade (firmware 3.6.0) I am getting a Mintemp error after about 1min when the bed temp reaches 30 C. On the subsequent restart from warm and its fine. This is happening with an initial bed temp of typically 19-21C.
Not a big deal but is there a fix?
Veröffentlicht : 31/03/2019 9:33 pm
Hobby Hoarder
(@hobby-hoarder-2)
Re: MK2.5S getting Bed Min Temp on cold startup
Same here, although my initial temp is around 16'C (it's in the basement, what can I do).
Veröffentlicht : 01/04/2019 4:09 pm
Clint Fisher
(@clint-fisher)
Same here - just did the MK2.5 --> MK2.5S + MMU2S upgrade.
Being in a frequently cold shop, I'm used to MINTEMP and even would set temps at 20C/20C post-print (can't do that anymore since it times out the heater). This new behavior is interesting because it *starts* to heat, and *then* throws the MINTEMP error. After a Reset, everything works.
While this behavior is waaaay better than having to get the blowdryer out to warm the unit, it seems to me there's no reason to throw a MINTEMP error at all if it's starting to heat and the thermistors are responding.
SO CLOSE! Hoping they'll fix this once and for all for all us cold-room dwellers.
Veröffentlicht : 01/04/2019 11:09 pm
tom.p
(@tom-p)
Yup me too! Couple of resets and its all good though. Just a little annoying!
Veröffentlicht : 02/04/2019 5:01 pm
