MK2 to MK2.5 Upgrade Guide
BM007
(@bm007)
As there is no guide to upgrade from MK2 to MK2.5 I thought I would document the process I used so that others could follow if they are doing this upgrade as well.
I ordered the MK2S upgrade and the MK2.5 upgrade kits.
Printed Parts
Once you receive the kits you will need to print parts required using the supplied filament. If you ordered both kits like I did, you will get two rolls of PET-G filament. This is more than enough filament. I printed two copies of everything (except the RAMBO parts), had a few first layer failures and an extra extruder-cover because I broke it removing it from the bed, all from one roll of filament. I printed two copies just incase I broke something during assembly (I didnt but its nice to have spares)
I found PET-G hard to print with initially, but once dialled in I produced some fine looking prints, some stringing but nothing too bad. I recommend using window cleaner to clean the bed. In the UK I dont think we have Windex branded window cleaner but I bought some generic cleaner from Morrisons and it worked really well. I also initially turned the print speed right down for the first layer, or at least until the intricate details were done. I turned it down to around 30%. This might not have been required after cleaning with the Window Cleaner. I also had to adjust my Z height.
You will need to print:
From the MK2S STL ZIP
Y-distance.stl - Use the PET-G profile in Slic3r set to .02 layer height. Infill set to GRID
From the mk25_upgrade_gcodes.zip
MK25_Extruder_parts_PETG_11H.gcode
MK25_RAMBo_parts_PETG_8H.gcode
Once all your parts are printed, check them over, tidy any stringing and check the all the holes are clear.
MK2 to MK2S
https://manual.prusa3d.com/c/EN_upgrade
Complete the following sections of this guide
0. Disassembly - I preformed the steps 1 - 7. I did not dismantle the extruder at this point. I felt it would be easier to keep track of the parts if they were still assembled. They will get disassembled later but I just did it when I needed them.
1. Y Carriage Drilling
2. XYZ-axis reassembly
MK2S to MK2.5
https://manual.prusa3d.com/c/Original_Prusa_i3_MK2S_to_MK2.5_upgrade
3. X-axis reassembly
4. E-axis assembly
5. Heatbed assembly
6. Electronics
At the end of Step 19 you will likely have a few missing connections for motors etc. Use the following illustration to reconnect them
https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/duCsG1ZS4kUCyrCe.huge
7. Preflight Check
Prusa support suggested doing a Factory reset after upgrading the firmware. I am not sure if this is totally necessary as I would have thought the firmware flash would wipe any settings, but I guess it cant hurt. Instructions on how to do a factory reset are here:
https://help.prusa3d.com/l/en/article/SYvbQ66IXF-factory-reset
Final Thoughts
I am not sure why there is no official guide for this process, it wouldnt be hard to put one together.
I found the build significantly easier than the original Mk2 build but maybe that was because I am more familiar with the printer in general. I didnt have any real problems with fitment or anything putting it together.
Read the guide carefully, study the pictures and read the comments. Sometimes the comments suggest doing the steps in a slightly different order to make it easier. Be aware that sometimes the comments suggest changes that have already been implemented so it can be a little confusing.
I hope this helps anyone doing this upgrade path.
Publié : 01/06/2018 11:03 am
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Re: MK2 to MK2.5 Upgrade Guide
great job there 😉 The guides are getting constantly updated based on your feedback and to my opinion sticking to the step's description will be enough.
To answer your question. There is no manual from MK2 to MK2.5, as it is not recommended. In the MK2.5 upgrade manual you are informed about getting MK2S upgrade first. The reason is that smooth rods, bearings and u-bolts are not included in the MK2.5 upgrade kit. I recommend getting at least them separately and also printing the parts, which are in the MK2S upgrade (namely the Y-motor-distance).
Assembly manuals
/ Knowledge Base
Publié : 08/06/2018 10:19 pm
Army Chief
(@army-chief)
I imagine a large number of MK2 users in the US didn't apply the MK2S upgrade due to the shipment cost equaling the cost of the upgrade, so they'll be applying the MK2S at the same time as the MK2.5 upgrade. Most of us that have built more than a few of these can figure it out for ourselves so we won't get lost and aren't duplicating parts and work between the upgrades, but others may have a bit harder time. Instructions taking the MK2 directly to MK2.5S (including new bed mounting and smooth rods from the MK2S upgrade) would be a great help and time saver.
Chief
Publié : 01/07/2018 5:18 am
Sudon
(@sudon)
This is great, thanks. The 2s upgrade kit isn't available anymore so I'm just gonna wing it here and hope for the best.
Publié : 31/03/2019 6:34 am
