Mk 2.5 assembly problem
Andreas
(@andreas-19)
Is there a trick to get the extruder cables into the Rambo Cover? For some reason I can not close the clamp when all cables and the nylon wrapping are in the hole.
Postato : 13/02/2019 12:10 am
Andreas
(@andreas-19)
Re: Mk 2.5 assembly problem
Ok, after testing it with the old spiral wrap, which worked, I asked the Prusa support if there is a trick to get the wiring harness in. They only suggested to wrap it tighter. In the end I got so annoyed, I took some pliers to squeeze the clamp together and that worked.
Still, would be interesting to hear, if one of you had the same issue. If not, then maybe something is wrong with the Rambo cover I printed.
Postato : 13/02/2019 12:04 pm
