Inaccuracy xy plane
Niekkert
(@niekkert)
Inaccuracy xy plane
Hi all,
Recently I set up my mk3s and got this out of the default Benchy gcode and Prusa PLA.
I've tried different belt tension, slicing myself and different models and flush out of ideas.
All the prints seem to have this rough part for all edges parallel to the the front right to back left build diagonal. On top of that, as seen from the top down view of the chimney, the model is deformed.
Any help or thoughts would be welcome.
Opublikowany : 26/09/2020 9:58 pm
1 ludzie polubili
RE: Inaccuracy xy plane
Posted by: @niek-gorissen
Hi all,
Hello and welcome to the Prusaforum!
I would check the complete mechanics again. Are the linear bearings are lubricated, the belt tension is correct, no loose pulleys, all axes run smoothly, extruder idler spring tension...
Opublikowany : 26/09/2020 10:27 pm
1 ludzie polubili
Niekkert
(@niekkert)
@karl-herbert
Thanks for the reply. I somehow managed to miss one of the pulley screws being loose a quarter turn the last time I changed the belt tention.
Running like a charm now:
Castle in .3 mm
New hull line looking good.
It's nice to be able to move on to improving other things.
Thanks again!
This post was modified 6 years temu 2 times by Niekkert
Opublikowany : 28/09/2020 7:06 pm
1 ludzie polubili
