Can I print without the filament sensor?
Metal
(@metal)
So I am a dummy. I had preprinted the mk2.5 upgrade parts beforehand but I received the mk2.5s kit.
I had mistakenly assumed that the parts were going to be pretty much the same for the extruder head. The problem is that I need to reprint the mk2.5s parts but I’ve already disassembled my mk2s and cut the rubber belt down to size for the mk2.5 upgrade.
So, I’m an idiot. If I continue to assemble the mk2.5 to print the 2.5s parts, can I still print if I don’t use the filament sensor?
The 2.5s sensor is a different size from 2.5
Respondido : 09/03/2019 11:10 pm
vintagepc
(@vintagepc)
Miembro
Re: Can I print without the filament sensor?
If it's anything like the Mk3, the S upgrade can be done without the new sensor, I was told by support it is simply disabled if it is not sensed. So while you can print, it (obviously) won't detect filament.
Respondido : 09/03/2019 11:15 pm
Tiago
(@tiago)
You can, when you switch on printer will detect the sensor, if not present it will disable that feature, otherwise you can disable at menu by yourself
Respondido : 16/03/2019 5:35 pm
Allen8355
(@allen8355)
RE: Can I print without the filament sensor?
The MK2.5 sensor is different than the MK2.5S sensor, and worse than that, there are actually TWO MK2.5S configurations. Yes, its a mess. The MK2.5 sensor was optical. The MK2.5S standard uses a ball bearing. The MK2.5S for the MMU2 uses even a different setup.
Respondido : 09/05/2019 5:21 am
