keeps restarting
superA
(@supera)
keeps restarting
hi
I have a prusa i3mk3s and I had to take it apart to tighten the heat block it went fine and started extruding filament then it starting printing but the layer calibration was off so I stopped it to do a layer calibration  I did one and wanted to do just 1 more to make sure I had it right I hit first layer calibration and it immideiltyl restarted every time I hit that it restarted then I tried printing restarted I flashed the firmware twice and hit the x I cant even remove my filament that I had in there so I guess its just going to be stuck in there I really need help thanks again
Opublikowany : 14/11/2019 4:03 am
RE: keeps restarting
X means reset.  You probably want to be pushing the rotary knob instead.
Opublikowany : 14/11/2019 11:56 am
Zoltan
(@zoltan)
Member Moderator
@agillespie1015
Did tim´s advise help?
Opublikowany : 20/11/2019 3:00 pm
