Nejde nahrát nový firmware ale starší ano
drahoslav.d
(@drahoslav-d)
Zdravím, udělal jsem upgrade z MK2 na MK2.5 MM2 a mám problém s nahráním firmware. Desku mám RAMBo13a. Aktualizace firmware dělám pomocí Slic3r PE - nahrát firmware tiskárny.
Do MM to šlo bez problému. Do ramba jdou bez problému verze na MK2. Na MK2.5 jde nahrát pouze verze 3.1.4. Jakákoliv novější verze už nejde.
Log verze 3.1.4
avrdude: Version 6.3-20160220-prusa3d, compiled on Nov 22 2018 at 15:22:47
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "D:/Winprog/Prusa3D/Slic3rPE/resources\avrdude\avrdude.conf"
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as FD
avrdude: reading input file "D:\Winprog\Prusa3D\prusa3d_fw_mk25-3.1.4.330.201804091650.hex"
avrdude: writing flash (228236 bytes):
avrdude: stk500v2_command(): command failed
Writing | ################################################## | 100% 40.63s
avrdude: 228236 bytes of flash written
avrdude: verifying flash memory against D:\Winprog\Prusa3D\prusa3d_fw_mk25-3.1.4.330.201804091650.hex:
avrdude: load data flash data from input file D:\Winprog\Prusa3D\prusa3d_fw_mk25-3.1.4.330.201804091650.hex:
avrdude: input file D:\Winprog\Prusa3D\prusa3d_fw_mk25-3.1.4.330.201804091650.hex contains 228236 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 29.23s
avrdude: verifying ...
avrdude: 228236 bytes of flash verified
avrdude: safemode: Fuses OK (E:FD, H:D8, L:FF)
avrdude done. Thank you.
Log verze 3.5.1
Using Port : COM3
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: reading input file "D:\Winprog\Prusa3D\prusa3d_fw_MK25_3_5_1_RAMBo13a_en-cz.hex"
avrdude: writing flash (222386 bytes):
Writing | #######avrdude: stk500v2_recv(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
avrdude: stk500v2_command(): failed miserably to execute command 0x06
avrdude: stk500v2_loadaddr(): failed to set load address
***failed;
########################################### | 100% 26.36s
avrdude: failed to write flash memory, rc=-1
avrdude: stk500v2_command(): failed miserably to execute command 0x18
avrdude: stk500isp_read_byte(): timeout/error communicating with programmer
avrdude: safemode: Sorry, reading back fuses was unreliable. I have given up and exited programming mode
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
Hledal jsem na netu a podle rad jsem zkoušel měnit USB porty i kabely. Vyzkoušel jsem i různé počítače. COM mám určitě nastavený dobře, protože by nešli nahrát staré verze. Nesetkal jste se s tím někdo?
Dík předem za odpověď
Postato : 11/02/2019 11:27 am
Václav Hluchý
(@vaclav-hluchy)
Re: Nejde nahrát nový firmware ale starší ano
Mám taky problém s nahráním nového firmware do MK3, jak tento problém odstranit, poslední nahraný firmware mám 3.5.0-1749
avrdude: Version 6.3-20160220-prusa3d, compiled on Feb 11 2019 at 18:25:11
System wide configuration file is "C:/PROGRA~1/Prusa3D/Slic3rPE/resources\avrdude\avrdude.conf"
Using Port : COM3
Problém vyřešen 😀 😀 😀 😀
MK3 připojena k stolnímu počítači na základní desku USB2 a vše začalo fungovat.
Postato : 13/02/2019 7:37 pm
